How do I figure out what size fuses to get for my system.
  • 2
vaa
4
Boston
So I'm upgrading my stereo in my car. It's a 2002 Civic. I will be doing the big 3 upgrade. I have a ED nine.1 for my sub and a Rockford P400-4 for the rest. The Rockford says it needs an 80amp fuse up by the battery. The Nine.1 has 120A worth of fuses on board. I'm wondering what size fuse I need up by the battery for these two amps. Do I just add them up? I'll be running 1/0 from the battery to my truing to a fused distribution block. What size fuses do I need here(an 80 for the P400 and a 120A for the Nine.1?)? I was going to get the Knu Knoceptz 2 Amp wiring kit, unless there is a better deal out there.
Also can someone recommend a god battery terminal that will make it easier to attach these wires?
Thanks for the help.
you fuse according to your wires rating, you said your getting Knu's amp kit their 0 gauge Fleks wire is rated for 300A and there KCA is rated for 250A, their 4 gauge Fleks is rated for 100A. all these rating are for a 20' length so shorter lengths will yield a slightly higher rating.
So the Nine.1 has it's own fuses. They are more than the 100A of the 4awg wire. Is that ok? Also the Rockford doesn't have any on board fuses so should I make that one an 80A like the manual recommends?
Is the knu Battery terminal a good one?
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
vaa
vaa
Boston
vaa
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
