how do I get 2ohm for my subs
mr-wolf
Hello I have a boss ph2.1000 2000 watt amp I'm kinda new with amps so need help it says it can but can't figure it out I have 2 12" type R's that are 2 ohm how do I run the amp for 2 ohm for both subs I looked it up only way I seen was run 4 subs but that can't be right can any one help
Ok subs are already In a ported box an I have the amp ontop of the box with the cap but the 2 wires from each port on the for each speaker on the box how do I hook them to the amp or set the amp for the 2 ohm I ha e a other amp that's ppl 2.300 tbats set 2 ohm stable an that one hits so much harder than the 2000 watt an I was told you run the 2000 watt each speaker run to each channel on the amp bit then I was told it was running at 4 ohm but didn't know how to change it to 2 ohm sorry I'm a dummy lol so its a lil hard for me to figure it out lol
An the ppl 2.300 sou ds so much better than the boss 2000 was told cuz its running at 4 ohms bit was looking for the more power for them than the ppl 2.300
So you can use a period to write '2.300' but not a lick of punctuation anywhere else, huh? I can barely understand your last paragraph and I'll leave it at this - the answer has already been given more than once.
Basically, whatever Ohm load you wire to the amp is what the amp will put out. For example, if you have one dual 2 Ohm woofer, and you wire it in parallel, the amp will "see" a 1 Ohm load. That said, the amp will run in a 1 Ohm capacity. Currently, there are no amps on the market where you can physically select what Ohm load you want it to run in. If someone knows of an amp that you can do that to, please let me know. I would be interested in looking at it.
Ok thank you bobinger!!! Like I says I'm dumb about rhis right now and new at it but thank you! And every one else! Sorry about the spelling some me amd some my phone :)
mr-wolf
mr-wolf
oshkosh wi
mr-wolf
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
