[X]ILE
I read a thread like this just a little bit ago, but I wanted to start my own because my situation entails a few unique problems.
I read that to install a quick kill switch for the amp, I would hook the switch to the blue 12v REM wire that comes from my HU and tells my amp to turn on or off, and I see how this works, but I don't think this will work for me. Let me explain why.
Alright, I have a 98 Ford Escort that had a pre-installed Pioneer DEH-P44, so I know that the head is working right. I spent about three and a half hours wiring up a 600w Sony Xpload the other day.
^This is how it's wired up.^
I tested it out to make sure that the power and everything were working correctly, and they seemed to be. (Let me say that again, SEEMED to be.) As in when the HU is on the light on the amp stating it had power was on, and when it was off, the light went off.
The problem I'm facing is that I have to manually turn off my head because my car will not turn off past ACC. I figured that by turning off my head the amp would shut off completely and draw no power, but this doesn't seem to be the case. I had to get jumped off three times before deciding to just unhook the amp, and since then, everything has been fine.
I had one person tell me that the power wire was not a thick enough gauge for that amp and another tell me it was fine. The wiring kit I bought stated that it was for up to a 680w amp, so I assumed it would work perfectly, but now I'm not so certain. Also, I do not claim to know much about any of this. This is my first amp and was my first time hooking one up, so I am well aware that this could be something I didn't do right.
But what I want to do is either hook up a kill switch to turn the amp completely off via the power cable, or have one that will kill the entire car. Any help at all will be greatly appreciated, and I thank you all ahead of time for reading this long post.
-Blake
-Blake
