How do i port a box?
  • 4
sethcal
hello, i have a box that is 17" long 20" high, and 12" wide. i have never ported a box before, do i need a tub? cause in the manual my sub came with it said for a 2.5 in tube that is 13 in. long. but the boxes that i have seen that have been ported have a slot at the bottom of the box. but if i have a slot, does there just need to be a hole or some more wood in there? thanx for anything you can give me. thanx
-seth-
You can do it either way. But the easiest way is to use pvc pipe. Just go to your local home center/ hardware store. And buy you a 13" piece of 2.5" pvc. Take a file or some coarse sand paper and round off the edges of the pipe. It wll help cut down port noise. Then cut your hole a 1/16th of an inch larger than your pipe. Then silicon your port in place. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by sethcal ok man thanx! but will that sound the best? thanx
As opposed to what ? best is a matter of taste. Porting it will make it louder, but at the expense of some of the frequency response. What kind of sub(s) do ya have ? I can run the numbers and see what kind of response you can expect. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
good chance.....im thinking about possibly porting my shivas after i get them....i might just end up going w/ one shiva and a jbl 300.1 .....depends on how loud they are in the sealed box....will probably sound good enough tho
Originally posted by Corsica So If i change the tube from cardboard to PVC I will hit harder??
J
it might add a 1/10th of a db. But it would be so minute you wouldn't hear it. We will talk later about making your subs hit harder. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
900
sethcal
sethcal
Russellville
Corsica
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
