how do I run components, coaxials, and a sub?
  • 1
seankurz
My head unit's manual only had diagrams for normal mode, 2 way mode, and 3 way mode, which I am attaching photos of. My question is how specifically do I run it the way I have it shown in the other picture?? With the complexity of systems today, I'm sure this is doable but I haven't found anything on how to so far, its been almost a day and a half of searching... //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:mad:
I will be running a clarion cz702 head unit, an image dynamics CXT component set on an alpine MRX-F65, a matching CTX coaxial set off of an alpine MRP-F300, and a RF 210 sub off of a power acoustic amp (going to upgrade to RE sub/amp in trunk)
How would I run this all out of the HU, specifically? do I need external hardware, or...?
i want to use the TA on the HU for the comps, but also keep the coax speakers and sub..
would the setup i mentioned be okay or is there a better way to achieve what i want to do?
HU rear rca outs>>>alpine MRX-F65>>>tweeters
HU front rca outs>>>alpine MRX-F65>>>mids
HU sub rca outs>>>fullrange signal>>>alpine MRP-F200>>>F300 rca outs>>>sub amp xover to filter out all but the lows.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
seankurz
seankurz
Tempe, AZ
seankurz
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
