(How do you connect a Battery Isolator??)
  • 3
depends on how you want to control the relay. the ignition wire will connect the battery when the car is on. yes, the red ACC wire on the head unit is an ignition source. note if you have a >2000 GM Vehicle, you can't use the Class II Data Bus wire as ignition.
There should be other ignition sources in the engine bay.
Great! Is it okay if I use the same wire coming from the ignition source on the isolator to power my amplifiers also. Itll be conveinient because my isolator will be in the trunk near my ampifiers and auxilary battery...
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
463
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
614
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
swollen_cu
swollen_cu
New Orleans
swollen_cu
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
