**How do you STOP the Retarded ROOF RATTLE?***
swollen_cu
Hi,
I have an SUV. Whenever the system is at high volume (not even full tilt) , the roof is hopping majorly around 2 inches and produces a loud ridiculous roof rattle. I already have a layer of sound deadner throughout the whole roof and it barely helped.
Any suggestions on the easiest way to resolve this?
Thanks in advance...
You can't screw MDF sheeting to the roof, you must glue. LOL. Unless you want screws popping out of the roof... Also no need for layers of deadener, it wouldn't make a difference. You are betting on the rigidity of the MDF here only.
Loctite and MDF is a very good combo for stopping both roof flex and rattle. Ideally you should get a layer of deadener down first then put some bracing attached to that
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
swollen_cu
swollen_cu
New Orleans
Kangaroux
    Jun 1, 2024
    May 31, 2024
