Here's the bare door under the plastic cover:
First my installer guy did was put a bunch of Damplifier Pro on each doors outer doorskin. But the pic was before the Damplifier Pro was applied. This pic shows where the 6x9 speaker goes, you can see the four holes. With a small hole in the door inner sheet metal just above it.
Those two big gaping holes were my first concern! I watched a youtube of some Second Skin sponsored shop guy making cool router table cut blocking panels for his door and RivNutting it on! VERY cool! I'm sure very effective too, but I thought I can do something kinda almost as good so I taped a piece of waxed paper over each of the two holes in the inner door holes and traced their shape on the waxed paper. Then I used that as a pattern to cut a piece of thin steel that shape!Then test fitted it on and trimmed accordingly.Then put 1/16" double sticky tape around the edges of the holes, pressed the metal patch plate on and nailed it down onto the foam tape with self tapping screws!
Then I had installer guy put BQuiet sound deadener on the inner door skins with the new hole patches!
Here's installer guy rolling the BQuiet on! Almost done!
All deadened: I was thinking of really extreme sound deadening by getting a bunch more Damplifier Pro because that stuff is amazing and deaden the outer door skins through the holes before blocking them then blocking one hole and through it sound deaden the INSIDE metal surface inside the door panel then more Damplifier Pro as shown with BQuiet on the outside. I was out of Damplifier! :-(
Had installer guy install a full door sized sheet of Luxury Liner Pro to the inside of the plastic door cover! Works quite well!
