How many batteries needed for my audio setup please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 5
man_n_da_trunk
Whats up car audio.com. Im a newbie here and i had to set up an account so i could get this question answered so anyone feel free to add input.
First off heres my set up.
4 alpine type x 12s
2 hifonic brutis 2600 amps they will be ran to produce 1ohm load. 2600 watt rms
1 hifonic zxi 800watt (for components)
4 alpine type r 5x7s
200 amp alternator
big 3 upgrade 0 gauge wire
i will be installing all of this in my 04 mercury grand marquis when i return from afghanistan in about 2 months. My question is though how many extra batteries will i need in my trunk in order to produce a power strong enough to push my system to the max. Also which batteries should i go with kinetic, optima, shruken or what please anyone feel free to post. And also one last question i also have a battery isolator but its only to connect one extra battery. How would i go about connecting the third battery please anyone help i want this system to bring it
I'd say minimum 2 good size + the one under your hood. I have my suspicions that most of the glass-mat batteries are the same, but others may disagree. Personally I go with batteries I know I can get a warranty on if they die early (Pretty happy with my Sears Die Hard Platinum)
Somewhere in the 400ah range will do you well(3 big batts, like HC2400 sized). Although better than stock, your alt will not be able to keep up with the current draw for very long, and voltage will drop to battery level pretty easily. With that said, you want a wall of stored power sitting at that upper 12V range so that voltage does not drop much below that.
Or just get a second 200amp alt, dual stock alts(assuming they're around 140amp stock), and add a couple of big batts in the back.
i was running 2300rms in my old caprice with a reg batt and a 100ish amp alternator. it dimmed but was still loud as fu ck. with a 200 amp alt, big 3, 0 ga, a good batt up front and 1 in back i think you should be fine.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
man_n_da_trunk
man_n_da_trunk
savannah, ga
Sleeklsc
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
