How many caps should i have???
  • Thread starter <thumpinblazr>
  • Start date
  • Replies 4
  • Views 2K
<thumpinblazr>
Guest
ok, i have a 1400 watt RMS @ 4 ohm mono amp running 2 12" rockford punch HX2's, i have about 500 to each right now. I have a 1 farad cap and a small alternator (either 60 or 80 amp). The lights still dim so bad that i dont really like to drive at night with any kind of bass at all. My question is how many caps should i have for 1400 watts if i dont want my lights to dim hardly at all? I was thinking of getting 2 more 1 farad caps? would that do the trick?
Also how much are high output alternators, do they hurt the cars electrical system, do they really make a huge difference, and are they worth it instead of more caps?
sorry for all the questions,
thanks in advance,
Dustin
That cap should be helping enough. I'd go with the alternator since a system is only as good as it base parts. You should be able to get like a 120 amp alt in like JcWhitney for 150 bucks, which is definitely cheaper than any good 1 farad cap you can get.
You need 1 farad per 1000 watts, so you might try getting another 1 farad cap. Or if you feel comfortable installing the alternator and you can get it for about $150, you can try that instead.
do high output alternators hurt your electrical system? i would think they would make the system work harder, is that right? cause if it is going to be about the same price and it wont hurt my truck, then i might go with the alternator.
The answer is no, it will not make your system work harder, it will just be better able to supply current to where it's required, not a bad thing. A friend of mine with a Ford Ranger upgraded his stock alternator to a high output one (I think it was 120Amps?), and he swears his system sounds much better, particularly on the low end. If anything, straining your stock alternator will shorten its life by causing it to work at max capacity longer. As well, it might shorten yours by denying the headlights their needed juice!!!
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
Guest
dcsoundguy
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
