How many db
des343
Do you consider impressive or at least above average? Opinions and or any statistics on the average system.
Just curious I want to know what is considered good for comp purposes and what would you consider good for loud yet musical purposes
Since your from Michigan and lots of 150db+ people here. I'm not easily impressed with anything. Takes 160db at 25hz to impress me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But really. If I have to pace my breathing I'm impressed. If you have a huge bandwidth like 20hz-50hz 150db+ that's pretty impressive
Wow. Loudest I've personally heard were 4 15 inch VFLs at full power. 2nd loudest is 6 10inch XFLs. What part of Michigan are you from? I live in battle creek and there isn't anything I've seen within an hour or two of me that would really "impress" me. Biggest I've personally ran was 4 12 T1s black models and 4 12 w7s which put the T1s to absolute shame. SPL and obviously SQ
Depends on the vehicle and setup. 2 18's walled in a civic on 5k doing a 150 not impressive a pair of 8's in a Tahoe on 500w doing a 140 is decently impressive. Burp only setups are cool but I respect being musical much more . I laugh when I hear someone bumping 2 12's with distorted factory speakers. A loud clean front stage can be just as impressive as high tl scores
Bay city Michigan.
Theirs my truck bay city 157db
Brandon's Hhr bay city he's 160db +
Mike Tahoe in Lansing 154db
Jeffs trunk car bay city 150db+
Got160s in caro he's 0db lmao
Kenny is in rebuild but was 150db
Anthony impala Detroit does 159db
Etc... Lots more I'm forgetting
If you can find enough volume to run a pair of 18's properly in a Civic I'm impressed. I don't think we got more than 9 cube out of my brother's after all displacement. Going to test 3 12's once the warm weather comes back around.
As far as what's a good SPL score it is very dependent on the vehicle and equipment.
Depending on the sub 2-18's might be ok in 9 cu others may need as much as 14. If you have surface room I'd do 3 15's depending on motors tc9's I'd do 12's neo I'd run 15's.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
des343
des343
Kalamazoo, MI
dbjunior
audiobaun
    May 19, 2024
    May 19, 2024
