how many rca cables do i need?
  • 4
jsluss17
my deck has 3 preouts front rear and sub. i'm planning on amping the front two speakers with a 4 channel amp and bridging it. my amp has 3 rca inputs one for channel A one for channel B and then an output. will i need a second rca cable for channel B also? and if i do can i just use the output on my sub amp and connect it to the input on my speaker amp?
How are you planning on bridging them? Bridging each speaker to its own channel or what? Why would you like to bridge them?
yeah im doing each speaker to each channel because the amp only puts out enough power to power 2 of them. or can i bridge both from one channel only? or is there any other way i can bridge it?
read your manual before you bridge, i know that some amps require an input in all 4 channels to achieve stereo, otherwise it will only play mono.
look the model number up on google. all you need to do is get a 2 y connectors if this is the case.
---------- Post added at 07:19 PM ---------- Previous post was at 07:19 PM ----------
model number should be on the amp somewhere.
its a pioneer gm 4000f if that helps at all
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
jsluss17
jsluss17
Scottsdale, AZ
kramer_212
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
