How much do I need to upgrade
Jager
Im going to be running a Orion 2500d to a fi btl 15. I have big 3 done and own a yellow top optima, and a batcap 800. not sure if I wan to run these batterys though. Opinions on what I should run, if I should keep these batterys... also what would be a good alternator choice?
What kind of vehicle do you have (do you know stock alternator output)? Will this system be used daily only or to compete? What group number is the optima?
Im from st. cloud too.. moved up here to go to school. But I have a oldsmobile intrigue, and im going for more of a daily setup. not sure what alt is stock..
That was gonna be my suggestion, if he has something like a 60 amp alt then I was gonna say depends on how big the optima is. Also can just turn the gain down a little, if your voltage drop is too much. Lets hope winter is over, I am ready to start my massive spring build //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A basic safe estimate is 75 amps per 1000 RMS watts. Or you can be more accurate and use the formulas. Power/Voltage=Current. Then you take Current/Efficiency of amp. I am not sure what voltage the orion is rated at so for sakes we will say 2500/14.4=174amps. Now I will take a safe side estimate and go with 70 percent efficiency. So 174/.7=249 amps. Since your going daily you can divide that number in 1/2 and get roughly 125 amps to safely run that amp daily. I think this is pretty accurate but if I am incorrect someone can chime in.
I would suggest 80 ah of yinglong lithium and a H/O alternator. I'm running 40 ah with a 320 alternator on a 3.5K and it isn't enough.
31
5K
If you have that much then yeah go for it. It's incredibly nice to just have the option. I remember the first time driving after I put it on...
16
3K
My apologies I forgot to mention what pic is what. First is sub control the 80hx blink and I got the picture as soon it it blinked 2nd pic is hpf...
9
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
Jager
Jager
Alexandria, MN
Team TH (Donny)
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
