How to bridge a 4 channel amp.
Ok thanks. Can I use 3 & 4 as well
Using a 4-channel amp is not optimal to power a single subwoofer. I'd trade it for a mono block or a capable 2-channel amp. Actually, in your case, you can't. If you tried to power each voice coil with a bridged set of channels, they would have to be 2ohm stable in bridged mode. Not a good idea IMO.
It is just for a week or 2 until I get a mono.. When I said can I use 3 & 4 also I meant. Could I use EITHER 1&2 or 3&4, not all at the same time. Thanks though
for most 4ch amps yes you can bridge 1+2 and you can bridge 3+4, making most of those amps "2/3/4" channel amps. You'll need to put the coils of your sub in series for 4 ohms. You can use the 2 other channels for front speakers or something.
As for how to accomplish it, that can vary per amp. Some will connect the negatives, flip a switch, and use the two positives for the speaker output. Some will connect L ch - to R ch + and use the other two for speakers. Some will connect L + to R - and use the other 2 for speakers. etc. Best to look in the amp's manual if it's not silk screened on the amp how to do it.
Not silk screened and no manual...
---------- Post added at 10:35 AM ---------- Previous post was at 10:34 AM ----------
and thats why i asked cause i noticed some used both negatives or both positives
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
460
Lowflyin
Sit on my face, B*tch
Lowflyin
FU JOSE, PA
Lowflyin
