how to determine inline fuse rating
  • 5
mat3833
373
florida
ok, so im going to be doing the Big 3 as well as pos and neg runs of 0ga to the trunk of my new car. i have 2 questions:
1. do i need to fuse the alt to battery wire for the big three and if so what size fuse?
2. how do i determine what size fuse to use for my power wire?
im goign to be running 0ga to a dristo into the 2 amps, then the 2 amps will run grounds to another distro which will run 0ga to the battery. i kno i fuse the pos wire, but im not sure what size to fuse it with. i will be running a kicker ZX-750 and a Autokek MM 1400.4(new model, 50 amps of fuse i think)
Matt
yes. the fuse rating is what the wire is capable of handling
again, you are fusing for the wire. so whatever amperage the wire is capable of running at that is the amperage fuse i would get.
Matt
answers in red
i thought you fused the amps power wire to what the amp would be drawing+10%. hmm, oh well. so 0ga is rated at 200 amps right?
Matt
For the power wire going to the amplifiers ive always looked at the total fuse rating on both amps, added them together and added another 10. Haven't blown a fuse ever
wait, so i have to fuse BEFORE the distro block AND after the block before each amp?
Matt
you dont have to run fuses at all, but it would be way more safe to have one upfront at the battery, think of how long of a run it is from the front battery to the back at the distro block. If anything happened in that run before the distro block like the wire was cut it would short to ground and there would be no fuse to blow and stop it and your car could burn to the ground... all hypothetical but, its possible
well i was planning on fusing ~ a foot before the power distro. and not fusing before each amp, 0ga fuse holders get expensive and i already need 1 waterproof one plus another for the power wire.
Matt
well ****, now i need 5 inline fuses. 1 for the Big 3, 1 in the engine bay for the power wire, one just before the distro, and 1 for each amp. god you guys make me spend money! lol, need 3 0GA and 2 4GA. anyone have a suggestion for a good quality inline fuse? id prefer them all to be weatherproof and secure.
Matt
Matt
like i said, if it was me i would do after the distro in between to the amps.
so you should have
alt to battery
battery to distro
distro to amp 1
distro to amp 2
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
I bought a second hand fuse board off eBay to pull apart and check. There is a massive AWG 0 or 1 cable that provides the main source. So I don't...
13
170
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
630
mat3833
mat3833
florida
mat3833
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
