how to figure out the Farad rating on a capacitor?
This isn't as easy as the title sounds. I got a free Capacitor from a friend. The Capacitor literally says nothing on it. No label of any sort, or any impressions in the aluminum housing (aside from scratches and dings from age) to give me any indication of the Farad rating. Is there any sort of way to test the storage or output to determine the farad rating?
I'll be running 3 caps along with the 2 batteries in my car. one on constant power, one on ignition power, and one on amps. I have no idea what his system is but it won't hurt anything really
I would toss it, from what ive heard, If you dont have enough Fared's it could hurt but you dont have to worry about too much Fared.....BUT keep in mind I am a newbie to this. lol
it shows *farad
capacitors have their place, just because you guys don't know how to use them doesn't mean they are worthless
I am pretty sure I know how to use a capacitor.
step 1) remove from car
step 2) place on shelf in garage
That is what I have done with the 15 farad that I was sold back in the day
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
closetcanibal
closetcanibal
des moines, IA
>>SQL<<
maylar
    Jun 2, 2024
    Jun 1, 2024
