how to fix sub
be sure and let the caulk/glue set for 13 minutes. Then take an old extension cord and cut off the female end, then strip the black and white wires, hook one to the + on the sub, and one to the -. What you are going to do is ensure the glue and tape mix gets a good seat, ok, you with me so far? allright, now here is the tricky part... now take the male end of the cord and...
This man speaks the truth! DO IT NOW!
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
So a hard-reset seemed to reduce the frequency of the issue, but it didn't go away. In fact, I can re-create it repeatably by going through...
john_doe_318
john_doe_318
bossier city
SPLaudio
Decebal
    Jun 10, 2024
