how to get loud in a ext cab
Fi4life
I have a 98 dodge 1500 extended cab. 28 cubes to play with. Choice of audio brand is fi. Any ideas what I can do to get loud with this space? I don't compete. Just daily demo musical. I have 2 18" sp4's 4th order wall with reinforced roof as a build. Any help is appreciated.
I have an 02 Dodge Ram quad cab..my box is 12 cubes after displacements tuned to 35hz. I've always had good luck with this truck getting loud regardless of what I put in it. Just build it big with lots of port area and throw a ton of wattage at it:)
I'm running ~4k watts on my current setup with 211 in^2 of port area and it gets loud enough for daily ground pounding..
Subs are 18" IA Death Penalties..
All I can say....It Takes Power To Make Power..and dont rush.or take any short cuts..Seal as much off as you can(all rear windows)/deaden as much as you can
I have an 02 Dodge Ram quad cab..my box is 12 cubes after displacements tuned to 35hz. I've always had good luck with this truck getting loud regardless of what I put in it. Just build it big with lots of port area and throw a ton of wattage at it:)I'm running ~4k watts on my current setup with 211 in^2 of port area and it gets loud enough for daily ground pounding..
How you liking that SS 4.6?
Bro ur all over the place. First u made a thread 3 15s or 2 18s? Then u made a thread about 8 12s in a 4th. Now ur making a thread for 2 18s.. And didn't u say u have a box builder that builds 160db builds? Let him build it.
I have a 98 dodge ram 1500 ext cab dodge with 28-29 to work with. Was wondering would 8 CT sound strato 12's in a 4th order (4 on top angling down and 4 on bottom angling up) be louder daily wise vs 2 18" sp4's in a 4th order. My mind is set to 4th order no matter what. My box builder who is known for 160db+ builds can get either done. I'm aiming for loudest daily musical. Amps will he 2 CT sound 4k's. Battery's and amps in a tool box. Stratos rated at 900rms each. Sp4's 3000 rms each. [/i]
You need to see Heath McCurdy's truck his is a MECA judge from Alabama , 3 x18" Fi Team's in a flat wall in a Silverado on around 10k does 155's legal @ the headrest, I think he peaks in the mid 30's and does 135 Park and pound 30 sec avg 6ft outside the vehicle , would be what I would recommend over a 4th with 2 x 18's for music in the space you have to work with.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
4
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Fi4life
Fi4life
Cleveland, TX
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
