How to make your own distro?
woody89
Boing Yoing
I noticed a lot of competitors just use a metal plate for I am assuming a distro? Since most run multiple runs of wire. My question is, how would you mount this down to the car? Obivsouly putting it on the frame of the car would equal bad news. I never really looked at how they were mounted/ put together, so I have to ask.
Lexan works well, and looks good too! Use a 1/4" X 1" piece of Copper Buss bar from Your local Electric supplier, get some plastic washers from Your local Hardware store for offsets and your golden! Use a thick piece of wood or lexan so you have some meat to screw too.
Good luck!
have any pics of that airmcn_3?
im interested in seeing that
-Robin
x2 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
-Robin
When I get to work tomorrow I will see what I can do about pics. I am in the Pro Audio Business, (Installer) We do Large scale Churches, Stadiums, ETC... Anyhow we use the same exact thing in our Audio racks, We have a 72"X2" copper buss bar that is mounted and Isolated from a Metal rack for Grounds. We use Lexan to Isolate.
Ill get some pics for you tomorrow..
Hey does anybody know how to find out your password so I can log on at my work computer??
Chris
Thanks airmcn. Just log in and type something in for your password, then it will open a thing that says forgot your password click here.
Why not just go w/ something like the two links below? The multiple buss bar is just like what the other member described making.
Distro Post
The larger 3/8in post has a 1-3/4in long bolt. You could mount multiple ring terminals on that and it's only $4.07 for the black one.
4 Point Buss Bar
This one is $10.69 for the 3/8in terminals.
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
woody89
Boing Yoing
woody89
Louisville, KY
woody89
    May 31, 2024
    May 24, 2024
