how to recone a subwoofer what you need to know video.
few things i see
cut the surrond then cut the spiders take the ring out last alot easier to get to.
use clear box tape to clean the gap around the pole and top plate. using the q tip first will push chips if present futher into the gap or worse under the top plate and they will reapear in the gap later making it rub/scratch.
dont apply the glue to the spider like that apply to the basket thick and heavy. if there is no ring also apply alot to the top of the spider so it soaks the spider/spider pack good.
there was no showing of aligning the kit to line up for direct leads on basket,shiming the coil or gluing the surrond to the basket oh and dust cap.
it was ment well im sure. also hope ya didnt use ca glue for the dustcap or surrond thats a no no....
few things i see
you should make a vid on how to do it the right way.
^ wouldnt hurt a bit sence drop in's are ez no skillz needed there. the hard part is in the set up and custom work //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hi, i have a b2 hn8p speaker and its blown, i was wondering if anyone has a reconekit or a suggestion for similar conekit so i can fix my speaker.
They all say they are in stock but they aren't. Just like my SSA Zcons and Evils were "in stock" but had a super long build time.
12
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
loudmofo
loudmofo
Providence, Rhode Island, United States
SPLaudio
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
