How to Secure subs?
I've always found that wedging the box in with a couple of cut pieces of wood is the 'easiest' way (sure its a little ghetto, but you can make it look nice)... also it allows you to be able to take it out if you need to get to the spare (unlike bolting it down, be a little more work)... As for the amp, the least room would be to mount it on the box... but if your car gets broken in to, the thief will for sure make off with all of it in one swoop.
I bought some velcro strips that are sticky on the backside from walmart and used the strips that are more rigid not the soft strip if that makes any sense at all and put the rigid strips on the bottom of my box. The rigid strips grip into the carpet and it hasn't moved since, not even when I'm out in the dunes going up and down steep hills and doin donuts all day, lol. I also used a staple gun to help secure the strips to the bottom of the box.
They screw it to the chassis frame and screw it on to the other side bottom of the car. Removing the car seat is harder to be done because it's...
18
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
907
663
16
muskymatt913
muskymatt913
chicago
ThatChevyGuy
