How to set gain for mp3 player
  • 3
Cadencefanatic
Hi everyone! This is my first post and I would like to know something about gain on an amp. I have a Sansa Clip MP3 player and I would like to know if setting the gain on my amp to max would be OK? The MP3 player itself has an output voltage of 18 mV at 16 ohms. The amp's highest gain setting is 260 mV. Would this allow any distortion to be present if I did? A lot of people say to never max out the gain on the amp. My amp currently has it's gain set to its highest setting and I don't hear any audible distortion. What should I do? Oh! And by the way my MP3 player is directly wired to my amp by RCA's as I despise my stock head unit. Future thanks to those who read this!
You're good there.
And don't take advise from people who say a setting that's on an amplifier should never be used. If it should never be used, it wouldn't be there.
You might also find that you gain some volume by installing a processor or line level amplifier. If you do that, you will need to properly set the amplifier's gain.
No you shouldnt. The gain on an amp is used to match the output voltage of the headunit not any devices that are connected to said headunit. The gain knob is not a volume knob.
Set it how you would normally set it using a DMM.
Thanks a bunch! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
I have no head unit. :p
Follow the equation for using a DMM for the clip to get the mV value that the amp gain should be set to. You still set it the same way. Maxing it out would still be wrong.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
755
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
6
174
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
674
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Cadencefanatic
Cadencefanatic
New Jersey
whitedragon551
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
