Hybrid Audio (HAT) C1 Tweeters and Legatia™ L2x Vertically-Biamplified Passive Xovers
  • 1
Nut Hair Trick
Pubes
Selling these together. I tried selling the xovers by themselves and didnt get much interest so I'm now adding the tweeters out of my Clarus Comps. When I ordered my Clarus comps, I upgraded to the L2x crossovers so I could biamplify the set. If someone is only planning to run one amp, a jumper can be placed on the xovers to disable the biampable function.
The manual for the tweeters can be found here.
http://hybrid-audio.com/downloads/specification-libraries-and-reference-guides/04_Clarus-Components-Manual.pdf
The manual for the L2x crossovers can be found here:
http://hybrid-audio.com/downloads/specification-libraries-and-reference-guides/Legatia_Manual.pdf
Tweeters come with surface,flush, and angle mounts.
Item(s) Description/Condition: Used for less than 2 years. Functionality 10/10 Cosmetic 10/10
L2x Crossovers are vertically bi amped passive designed to work with any wide bandwidth Hybrid midrange. They are very nice looking, high performance filter set that contains hand matched high quality low tolerance parts such as metalized polypropylene capacitors , air core low ESR inductors and low tolerance ceramic resistors. Has tweeter protection circuit to defend the speaker from being over driven or from faulty amp circuitry and extreme input voltage. Double sided design with nickel plated spring loaded terminals for ease of install and adjustment of tweet attenuation.
$200 Shipped
Flat rate USPS shipping on me
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
7
4K
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
3K
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
7
3K
A Link would be very helpful. Id be interested in taking a look at some gear
206
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
Nut Hair Trick
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
