I Cant see
a1steak
va
Hello all,
I have an Audiovox AV1510D Dvd/cd player with 7" screen and a 2004 dodge neon. I have installed it into the car and everythin works fine except that when i try to play a dvd there is a blue screen that says parking on it and i cant see the movie but can hear it. So i was wondering what i need to to do to fix it. The wiring harness doesnt have a wire for the brake but the audiovox does. so i was wondering what i need to connect the pink brake wire to to get the video to show on the screen. Thank you for any and all help you are able to give.
thats lame, sounds like the bs the pioneer does, i just got a planet audio dvd player from the flea market and put it on my glove box and hooked everything up and never had it any probs with it
does it do this all the time or only when you are driving? try reading the owners manual because if it happens all the time then its not grounded to the parking brake and if it only happens when your driving then its installed properly.
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
805
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
a1steak
a1steak
va
bonesninja
