I have 3 amps but dont know where to put them??
Only The Best
texas
i have a dodge ram 1500 2005 slt four door truck with 2 batterys, 1 of which is wired and under my back seat in one of the 2 deep spots. i have 3 amps, a rockford fosgate 1000.1 bd, 300.1 fosgate, and a 4 channel eclipse amp. my friend told me an amp rack would be good? but i have no idea where to find one or make one. maybe another option would be good? LMK!!!
You could sell all the amps and buy a ppi phantom 900.4 for your front stage and the ppi phantom 1000.1 for sub stage. If you did that they would all fit in the console . Just an idea.. They are very small amps with really good specs and power, and money wise you could buy both for like 360$ shipped.
If not something like that if I remember the dodge correctly behind the rear seat there is enough space to mount them to the back of the cab.
the 300.1 is for an 8 inch sub in my roof and the eclipse amp that i HAD blew when i was trying to install the speakers somehow? and it wont turn on even though it was working while i was changing from speaker to speaker to see what wire went to what and then i was going to the next speaker and the amp shut off and wouldnt turn on even when i ran a wire straight from the control to the power.
all four of the fuses on the eclipse are fine. i know its bad but i dont have a fuse going from the battery in the back of my truck to the amp... i have a fuse from front battery to the back battery but not fromt he back battery to my amp.
the amp location can also depend on how your substage is laid out....if you have a large enclosure you can mount the amps or amp rack on one fo the wall on the box or below the rear window if you have space..there are many options but we need more info
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
440
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
567
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Only The Best
Only The Best
texas
momax_powers
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
