i have a 1200 watt s channel amp and a 500 watt sub.
  • 4
Are you running it bridged? If so then ur running 4 ohms bridged. Specs on that amp are 1200x1 br @4ohms...(laughter aside). It has a 25 fuse, which I'm thinking that that amp will put out around 200 watts total. After thumping for a little bit check the sub to make sure it isn't warm(amp also), if not then ur fine, if they are hot turn the gain down on the amp. You should be fine. Hope this helps. Good luck!
Yes you can. It's ohms law:
Also... there is a cool little smart phone app called Audio Toolkit. It has a number of useful calculators in addition to a power calculator.
It should be fine as long as you're not looking to upgrade in the future.
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
  • Locked
I have one if you are still looking
stp4160
stp4160
portlan or
bbeljefe
    May 31, 2024
    May 24, 2024
