I immediately blew my new subs.
I just installed all my car stereo at one time as follows:
Pioneer AVH4400BH
Alpine TypeR 6.5 comps
Alpine TypeR 6.5 coax
Kicker PKD1 0gauge kit
2x Alpine SWR-10D4
Alpine PDX-F4
Alpine PDX-M12
Sound Ordnance Bass Bunker dual vented enclosure.
Everything sounded amazing for about a week and a half then I stupidly pushed the limits of the gain on the sub amp, the subs fully extended and fried.
I thought, wow, that was dumb.
So I bought 2x SWR-10D2.
I turned the gain all the way down and unplugged the power to the sub amp. Installed them. Plugged in the power, no sound from the subs. Music playing quietly on the headunit. Unplugged the speaker connector and plugged it back in, subs immediately fully extended and fried.
What caused this?? Thanks for help in advance. I am afraid to plug anything else into the amp, I have already pissed away $700.
Pioneer AVH4400BH
2x Alpine SWR-10D4
Alpine PDX-F4
Alpine PDX-M12
the user
well, how did you wire down the impedance on the subs? each set? second, you never turn up the gain on your subs unless you know what your doing or set it properly with a DMM or o-scope
You probably wired these D2's to .5 ohms.. and you do have a good amp.. so you were probly giving them waaay too much power, and too low of impedance for the amp also..
You gotta learn to play it safe, or just learn from mistakes (expensive mistakes in your case)
you should read the tutorial on setting amplifier gains.. also, you can probably get those subs replaced under warranty. That amp is rated at 2 ohms so you need a 2 ohm final load, meaning that if you want to run 2 type R's, you need the D2 version, but wire them to 2ohms final. You can check the impedance thread for info on how to do this.. now, when you hook all of your crap up, make sure all of the amp settings are at 0. Gain all the way down, bass boost all the way down, etc. I would even keep the filters down until you set the gain properly. Also, make sure the settings on your head unit are at 0 as well. the bass, subwoofer settings, "loudness," etc. keep them all at 0, then properly set your gains.
Well aware, Thanks.
The first set I had wired to 4 ohms. The new set was at 2 ohms. What would cause the second set to blow immediately, with no gain present is what I am trying to find out.
Why the helll would you turn your gain all the way up?Its not a volume knob.
I never said I turned it all the way up. Just too high.
Pioneer AVH4400BH
2x Alpine SWR-10D4
Alpine PDX-F4
Alpine PDX-M12
Why did you unplug shit with your music playing?
Well aware, Thanks.
Are you absolutely sure it was wired to 2ohms final? Did you check with a DMM?
You must have accidently wired it to half ohm, because theres no way that two type R's will immediately blow off 1200rms and minimum gain. I had two type R's on 2400rms+ for like 2 years
I double and triple checked the wiring, they are definitely wired at a 2 ohm load.
i bet you paid out the *** for all that on crutchfield
I paid less than 1500 for everything on eBay and amazon combined.....
The 'level' for the subwoofer rca out was at 1, eq was flat, no bass boost or anything on. Nothing that should blow it up immediately like it did.
Good question!
The wiring matches perfectly to that of the diagram, jumper in the middle posts, then to each other, then to amp.
That's what I thought !
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
853
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
8
900
Thanks for all the help guys I'm going to buy a new sub, looking at some of the suggestions u guys gave. I have a small sealed box now but will...
41
4K
therockdrummer
therockdrummer
Scottsdale, AZ
xSPLoder
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
