Rangerboats
Hi guys and thanks for your help and time. I'm going to be putting some subwoofers into my truck, a 2012 Nissan Frontier Crew cab and needed some advice. The subwoofers will be two American Bass VFL 8's in a 1.5 cube ported box at 34hz. The amp will be an Incriminator 10.1 with the subs wired down to 1-ohm.
The questions are as follows. Will the two subwoofers be able to take the Incriminator 10.1? Also is a 1.5 cube box with both subwoofers in the same chamber going to work or do I need to design another box for them. The box I am going to use is a box I found on this site designed by another member because I have no idea how to design a subwoofer box. Here is the box I found on here to use for them.
Also I have a small Alt on this truck and think it is around a 120 amp so I was going to buy an extra battery to use for the stereo, should I get an AGM battery and what size battery would I need?
Here is a breakdown of the entire system..
Head unit Kenwood DDX774BH
Mids/highs are a set of Cresendo 6.5 with 6.5 in front door and tweeters in dash
Mids/highs amp is a Boston Acoustic 2125
Subwoofers are two American Bass VFL 8"s in a 1.5 cube (Shared) Box at 34hz
Sub amp is an Incriminator 10.1
I have the big 3 done and I am using Knu OFC 4-Ga on the mids/highs amp and Knu OFC 0-Ga on the Subwoofer amp.
Thank you for all of the help guys.
