I need a radio safety
I'm thinking lock the doors, put up the windows, and sit in your window with a shotgun and watch out for the guy with the Head Unit Evaporator Beam to come back, then blast him. Or just beat him over the head with a 1 farad cap. Don't show your stuff off. Worst thing you can do . People will always like your stuff more than you do if you rub it in their faces.
Dudei think he means to bolt it to the frame of the car so ythe HU takes along tym,e to remove. Try rrmoving tha Faceplate when u leave sop it looks blank to theives and they should pass by for something a little better to go.
J
Tex, if you have Sirius/XM, were you able to use your OEM antenna or did you have to install the one that comes with the kit? Good job on the...
28
4K
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
214
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
180
phucing_shet
phucing_shet
Quebec
Corsica
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
