I need help wiring
  • 2
ranora6
CarAudio.com Newbie
I need help wiring
So i have a problem. Lets start with what i have. I have a pioneer 1000 watt 4 channel bridgeable amp. I have two 2 ohm DVC scar audio subs with 500w rms each. If i wire the two subs into series parallel for a final impedance of 2 ohms how do i wire that into the amp in a bridged configuration without blowing the amp. Online people state that the amp can handle 8,4,and 2 ohms
Attached is a pic of the specs of the amp. Whats confusing me is the amp specs state that maximum power output is 500w x 2 channels ( 4 ohms bridged)
I want that. How do i wire that into the amp if series parallel only gives me two wires that go to amp. Also why do the specs say (4 ohms bridged)? Is 4 ohms the final impedance i need on each subwoofer plugged into two different channels bridged what i need to achieve 500w each?
Tldr: i have a basic understanding of subwoofers and need help wiring because im dumb 😂
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
11
545
663
ranora6
CarAudio.com Newbie
ranora6
colorado
HardofWhoring
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
