I need help with my 07 navigator thx certified system.
  • 2
Is the Auto Volume Level option engaged? If that is your issue, I have read other members disconnect the microphones on the rear passengers headliner. I hope someone better versed in this technique answers your query.
The speed volume is turned off. The system does it all on it's own. I'm considering replacing the head unit with an after market unit. Hopefully that works. If not I'll start slowly replacing the lamps as well.
552
671
939
Mykal1980
Mykal1980
Wisconsin
Mykal1980
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
