I need some help here...
  • 5
you don't need to bridge a mono amp.
you're gonna want to wire up the subs like this -
And the amp will do 1000x1 @ 2ohms which can also be looked at as 500x2 @ 2ohms.
the whole thing that messes me up is how do i go thru the terminals in the box? do i not use one since only 2 wires go to the amp from the box?
you can use 1 terminal cup, and then just wire up the rest inside the box since it will never change. you know what I mean?
that scared me there for a second, i was concerned how i was going to use 2 instead of 1 then u throw 4 out there and i dont even have 4 haha
I have both positive wires in one terminal on my amp. Same with negatives. So you can use both terminal cups on your box.
either way will work, Just whatever is easiest for you I would think.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
671
11
957
919
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
Fender91
Fender91
Fender91
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
