I need some help
  • 2
AsianPerzuasion
I'm new to car audio stuff and this is my first so suggestions would be most helpful //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
Car: 1999 Pontiac Grand AM 4 door se
Headunit: KD-A735BT it has 3 Pre-Output Terminals being 4.8V Line (Already installed in the car)
Front speaker: Pioneer TS-A1605C Component speakers (RMS 5-60 watts each) 4 ohms Impedance I'm going to have to mod my doors to fit 6.5 speakers
Rear speaker: JBL GTO938 coaxial (RMS 100 watts each) 2 ohms Impedance (Already bought)
Amp: Pioneer GM-D8604 4 channel
|4 ohms: 100 watts x 4 chan|
|2 ohms: 150 watts x 4 chan|
Pioneer GM-D8604 600W RMS Class D 4-Channel Car Amplifier
Questions:
1. Is this a good setup for the price? Just looking for some good sq nothing extreme.
2. I understand that the amps power line and remote line stays on one side of the car and the RCA stays on the other side because of interference. So which side do I wire my speaker wire? Not sure if the speaker wire will be affected by the powerline side or will the speaker wire affect the RCA side.
3. Can I have some recommendations on speaker wires and RCAs? sizings and brands for the speakers.
4. Is this amp alright? I live in the sun belt region so it gets hot here during the summer so I guess I should buy a class D amp? Can't spend more than $160 on an amp if there are going to be any suggestions //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
The amp is fine and I've run speaker wire next to rcas and power wire with no problem for years. Long as the power wire is seperate from the RCA you should be fine. The front door speakers are ok but for a lil bit more money u can get the 6.5 d-series components from pioneer and enjoy a nice boost in sq.
The amp shouldn't get too hot as long as your voltage stays up.
Amp Installation Kits, HDMI Cables is a great place for amp kits, wire, rcas, etc
I like the kord speaker wire 16g would be plenty big enough and I run karma rcas but I've had good luck with the cheaper rcas as well.
According to Online car stereo.com
Speaker Specifications
Front Speaker: 4X6 - Depth is 2.5 inches
Front Tweeter: 1.5 - Depth is 2 inches
Rear Speaker: 6X9 - Depth is 4 inches
So that means I can fit Pioneers 6.5 d-series components without it interfering the window?
For my AMP can I get (KCA Kable 4 Gauge Ultra Fleks Blue CCA Power / Ground Cable) or should I buy the (Kolossus Fleks Kable 4 Gauge Black Power/Ground Wire) I know its a CCA vs OFC but do I really need the OFC for my system? Any money I can save the better just want to know if its worth the extra money
The kca is fine for just that amp. If you wanted to add a small bass amp the kolossus is better because you can split the wire for two amps with up to a 150amp combined draw whereas the kca is only good for 80amps max. Which two kca kits are better and cheaper than 1 colossus kit but the collossus is less wire to deal with and better wire over all.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
140
11
721
760
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
978
AsianPerzuasion
AsianPerzuasion
Gulfport, MS
winkychevelle
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
