I want to increase the shaking in my Car.
****Scar audio Ported Box **** (n)
There is a song by Travis Scott called "Don't play" and it doesn't hit hard as I want it. I don't know if its the bass but there is a rumbling in the track that should shake the car but doesn't.
Sounds like a typical higher tuned/prefab issue to me, try to play far enough under tuning and your subs will basically freeair without the added output/control around tuning a ported box delivers. A prefab is usually listed airspace/tuning wise without speaker displacement accounted for so a 1.75ft3/36hz might change as much as 1.55ft3 almost 40hz tuned after displacements with a beefy enough sub. Plus lack of port area can be a real hinderance with prefabs at times.
Now imagine playing with power at the subs limit and you'll see why a ssf is recommended for most ported setups.
what ^ said. amp gain setting info, test tones are at the very bottom...
620
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
225
A Link would be very helpful. Id be interested in taking a look at some gear
232
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
669
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
JustinKG
CarAudio.com Newbie
JustinKG
United States
shredder2
Decebal
    Jun 10, 2024
