I want to use my stock head but it has no preamp outpts
  • Thread starter chaos
  • Start date
  • Replies 3
  • Views 1K
  • 2
You can either purchase and amp that has high level inputs as well as low level inputs. The high level inputs will take 2 channels from your factory deck and use them as a signal source rather then rca's. The low level inputs are simply rca's incase you want a future upgrade. Also, there are converters out there, Ramos or someone else can tell you the name probably it escapes me right now but it will take two channels from your deck and convert them to an rca line which you can then simply pop a set of rca's into your deck and your amp. That would be my preffered method of the two they you can continue on with any amp you like, not all have high level outputs.
what you need is a high to low level converter. the nice thing is you don't have to lose the set of speaker outputs that run to it you can run wire to the speakers and splice the adapter in just about anywhere. all car audio stores have them as well as walmart circut city. best buy, .......etc
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, so basically it’s still a ground loop? But then why would the alt whine go away but the other constant whine stay Sorry I’m just pretty new...
8
Have you contacted crutchfield.com support. They sell modules that allow you to retain the steering wheel-controlled factory features for some...
9
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Guest
BlackSunfireGT
