IB Install Help?
Even though they have an FS of 39Hz, and I had a 25Hz 12db/oct subsonic filter, I measured this in my cabin:
It was a calibrated measurement, that is actual SPL. Not a record or anything, but still quite loud for 12Hz on 10 year old TB subs.
WHY?!? We were trying to test for a low frequency phase difference between two microphones using our acquisition gear - for the purpose of looking for phase of low frequency noise in an HVAC system. I figured my car would be able to produce adequate SPL levels at 12Hz (problem frequency for the HVAC system). So I put one mic in the trunk and one in the cabin and measured them at the same time. One downside to this test is that I could hear my vented woofers moving in response to the pressure. Which got me to thinking: does high SPL at low frequencies pressurize the speaker cones in the front of the car, causing distortion? me thinks so...
One interesting piece of information is that the harmonics in the cabin had a much lower amplitude than they did in the trunk. I'm not quite sure why that was and want to do further testing...
With only 180W RMS per sub as a rating i dont actually get to, from a fully regulated pre-motel xant amp, the output is enough to induce pain while remaining clean and clear. Plenty loud enough for me.
I haven't measured SPL yet, i have a mic good to 140 dB. Not sure I care though. I'm all about accurate reproduction. SPL is science, math, and acoustics. I could build a helluva SPL rig... If I wanted to.
we should all post up our calibrated measurements at 12Hz and see what we can do... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a Phoenix Gold Cyclone sitting in my basement I could dust off and hook up...
probably 100W RMS of power, EQ'd for SQ, 10 year old subs, subsonic filter, and i wasn't really pushing them. the test wasn't for SPL but to test pressure measurements for phase response.
I was thinking maybe 2/3 Fi X 15's off if a Big Bells?
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
Bettr n' Revrse
I do what I want
Bettr n' Revrse
Grand Junction, CO
Bettr n' Revrse
