Image Dynamics XS65 Mid Woofer Pair
area51
Image Dynamics XS65 mid woofer pair I had in my closet. Ran it for a month then swapped them out for my L6s. They have some slight rust on the magnet area. They are working fine with no problems. Set comes with box, grills, cut out paper and midwoofers.
Specs:
6-1/2" XS Series Car Mid-Bass Driver
Power Handling:
Peak: 500 watts per set / 250 watts each side
RMS: 250 watts per set / 125 watts each side
Recommended Power Range: 15-125 watts each side
Multi layer ceramic fiber and Rohacell composite cones
Parabolic rubber surround
Nomex spider with a progressive roll
Fiberglass composite non resonant basket eliminates reflective distortion
4 ohms impedance
High temperature and high power voice coil
Neodymium magnet structure
Top-mount depth: 3"
Sensitivity: 92 dB
$160 OBO plus shipping
Via USPS
Need more pics? lmk
These are $300 on sonicelectronix.... someone will be getting some VERY nice mids for cheapz. I'd pick these up in a hot second if I were piecing together a comp set. GLWS.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
3K
I could swear Ive seen those years ago. I wouldnt waste money on it
112
9K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
area51
area51
Honolulu, HI
area51
