Installation Question for Factory Bose System and After Market HU
  • 3
heather g
Hey everybody!
Sorry for being a pest, but I am just about ready to pull my hair out!
I have a 1995 camaro that has the factory bose system in it. I have googled until I just can't google anymore. And since no one where I live seems to know how to fix my problem, and the audio store wants an arm and a leg. I thought I might ask y'all! =)
I have the factory sub in the back, two rear and two side speakers and original delco/bose head unit. I have tried FOUR different decks all with the same response. All with the harnesses. I can connect my aftermarket deck, everything works great for about five minutes. Sometimes shorter. Full power...all functions....full sound. Then.......I lose all sound. Everything else works. Power is still on....all functions work but no sound. And this is with EVERY deck I have installed.
I am about ready to give up. I am doing this all myself. No help....just me. I eventually want to replace the entire system but until then........
Anyhow......thoughts anyone? Lol
Thanks!
Heather
Honestly, I am not sure if there is a factory amp or not. I'm not sure where it would be located either.
Blown fuses? Not yet.
If I reinstall the factory unit system works fine.
Thanks for the response!
It's a factory amp. The deck is also amplified and you can't run the two amps together unless done they the rcas The amp is either in the pass side kick panel or on one side in the reset quarters you need to bypass it completely. Which means you'll need speaker wire 4 runs from the deck to where the amp is
Mylows that is probably what I am gonna do. Just run new wire bigger gauge and just bypass it then. Sound better with a better wire anyhow.
Thanks so much y'all! Off to rewire!
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
heather g
heather g
elgin, alabama
heather g
Decebal
    Jun 10, 2024
