Ipod attachment to JVC Head Unit.
  • 1
ticktockhouse
UK
Hi All,
Please prepare yourselves for a potentially very dumb, newbie question which I am forced to foist on you all...
Also, apologies if this has been asked elsewhere...
I have a JVC KD-G502 head unit: FM/AM Radio, CDs and MP3 CDs, so far so groovy. So I got a generic Ipod adapter attachment for it off ebay, plugged it into the CD changer port and can now play my ipod through it. It pipes the sound through very well.
The only thing is, there were two, obviously electrical, cables also hanging off the adapter, and I had no clue as to where to plug in or attach them. I get the feeling these would charge my ipod when it was plugged in. Now, this being a generic ebay jobbie, it came with absolutely no packaging or instructions on where to actually attach these electrical wires.
Scouting around on the net, I found some instructions for another, for all I know, identical adapter (http://www.discountcarstereo.com/pdf/pxp.pdf) and these state " Connect the red wire to +12V “ignition wire” and the gray to ground".
So my question is, and I feel really stupid for having to ask it, where is this "ignition wire"? Would there be some kind of pass through on the head unit? I assume I can attach the black wire to the chassis of the car somewhere, or do I need to run a wire through from somewhere else to connect up this red wire?
Any help would be very gratefully accepted.
Thanks
Jerry
I would turn it to either flat, or better yet off if you have that option and use the head unit to control the eq.
4
I had to go from the headphone jack to an rca converter and plug into the back of my head unit. My old iPod won’t directly connect on any of my...
5
948
Google do it translate what ever i do
4
394
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
ticktockhouse
ticktockhouse
UK
ticktockhouse
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
