Is it cool to bridge when it says not too?
  • 4
rocca_dogg
More ThUmP in the Trunk
I just got a new 200watt amp that I was planning on using for my 2 6X9s but the only problem is that it's 4 channel and It says it bold letters "NEVER BRIDGE OUTPUTS FOR USE WITH TWO SPEAKERS" So whats the dealio, is it just not recomended or are they for real??
first of all what kind of amp is it? second of all it shouldnt matter. u r going to be using only 2 channels and will have only one set of rca's hooked to it so as long as u use left + and right -, it will be all good. and also u have jvc 6x9's so they arent rated at what they say. so yeah its all good.
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
Thanks! It may never have made it to U.S. retail. Actually, I highly doubt it! They have diversified their product line now as can be seen on...
7
rocca_dogg
rocca_dogg
Coeur d' Alene
FantomForce.com
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
