is it okay to set LPF at 100hz?
100hz is fine. you should set it to where it sounds best for you. 100hz can really help the midbass of your front-speakers, although the subwoofers may sound a very little bit "sloppier" than if it was set lower.
335
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
746
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
824
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
talon2nr7588
talon2nr7588
Indiana
Max_Power
    May 31, 2024
    May 24, 2024
