is it the amp or wiring kit?
  • 3
beartoe
I am having some problems with my amplifier. it will turn on but when I turn the volume up the amplifier will shut off. The amplifier is brand new but I'm using an old amp wiring kit that is 800 watts with a 900 Watts amplifier and everytime it shuts off I'm able to switch the wiring kit fuse with another one and it will turn on but it will do the same thing and cut off and I will go and put the other fuse back in and it will turn back on but it will do the same thing and cut off again but both fuses are brand new so is there something wrong with the amp or is it the wiring kit itself
Check to make sure all your wiring is really tight and that the ground is making a solid connection. By solid connection i mean where you grounded it to the car not the terminal in the amp. I know in high school my system would always turn off cus i half assed tightened the bolt for my ground so it wasnt making good contact. hopefully that helps.
If say it's the amp kit. Or just the fuse block if the old kit was rated for 800 watts I'd be almost certain it's a 8 gauge cca kit. Get a 4 gauge ofc kit and be done with it
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
623
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
beartoe
beartoe
Baton Rouge,LA
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
