Is my amp not strong enough for my sub
lynchmob53
I have a 10" Pioneer TS-W253R sub connected to a Jensen UV10 HU and a Pioneer Amp GM-5400T. When I first hooked it up the sub hit pretty good with the gain set at normal and after about a month it started cutting out. I now have the gain all the way down and can barely make out the sub. What could be my issue?
Thanks
How did you have your sub wired to your amp? Try hooking an iPod up to your amp (using something like this:Monster® MusicConnect™ Portable Audio Player to Stereo Cable - RadioShack.com) to see if your amp is cutting out or if maybe it's a source problem.
Also, how is your amp grounded? Cutting out is often a bad ground. Are any of the protection lights coming on?
X2
I had a sub once grounded to my seatbelt bolt and the ground cable broke at the terminal! my sub would get very static filled and just flat out cut off - but the amp would stay on.
Also check how your ground is going into the amp - it may have wiggled loose
re check the ground, heck pull it up and out of the car and do it all over again
118
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
321
6
456
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
746
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
543
lynchmob53
lynchmob53
Hastings, NE
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
