Is my amplifier busted?
Dunsmoor
Installed a sub in my silverado single cab behind the seat. Boss amp purchased brand new off amazon. The sub is a kenwood brand new off amazon too. For 3 months it worked perfect but then things went down hill. First, the sub would sound distorted like it was blown but then a short while later would sound mint again. Then it got worse and the sub started to stop all together randomly. At first I could get the sub to work again by pushing its edges inward a few times but then it stopped all together and hasn't come back.
I used a buddies $400 sub and attached the wires from his sub to my amps positive and negative wires and it sounded mint for a minute then sounded distorted then cut off.
Next, I replaced the fuse in my amp and cleaned and repositioned my ground. Still nothing. The amp shows power but sub isn't playing.
As of tonight (March 9th) I tried to do a run through of it quickly and check everything. All that happens now is the sub has some power going to it, I can feel it kick lightly with the bass, but its not nearly enough to be heard at all. Even with amp settings to the max it doesn't change from a light clean small thump. its almost like the volume for the subs bass is all the way down. adjusting the jvs head unit settings doesn't change anything either.
Anyone know what this could be? I'm out of ideas and am not looking to start purchasing a new system piece by piece.
You bought a boss amp what do you expect? People don't recommend boss for a reason. They are ****** amps.
Sent from my 5054N using Tapatalk
---------- Post added at 02:50 AM ---------- Previous post was at 02:49 AM ----------
Try your sub on your friends amp
I'm running a Boss amp right now and it slams wired at .5 ohm //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
But you're lucky if it's doing 1/4 of its rated power even on the test bench. This guy probably bought a $50 boss off Amazon
Is was $100 bucks and so what if it only does 1000watts for $100.
I'm saying they are over rated and don't do any where near rated. OP probably bought the amp that claimed to be 1k and actually only does 100watts
You didn't sell it for $100 to a local friend?
Yep, then traded my 10" L7 for the amp back and a pair of Rockford P3 motors
Traded is back for the kicker l7
Yep, you know what's up
Yeah, 1/4 of rated. KHA got 1k out of his clean and it says "4k"
Yeah, I don't think it's bad for the money. I'm legitimately impressed at how much it moves the Wardens. It moves my doors!
Yeah, I'm partially messing and partially impressed by what this amp can do. My doors shake at full tilt like the TFE made them at 3/4 max output
Not talking **** about yours I'm just saying op probably bought the cheapest one he found that said it would do the power he wanted
My Boss 4k was $129.99 //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
564
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
949
933
Dunsmoor
Dunsmoor
Pepperell, MA
jb4674
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
