Is my stock head unit hurting my sound quality?
  • 4
Madeinoregon
CarAudio.com Newbie
Recently had a JL stealthbox and JL 5 channel amp installed in my 2019 Silverado. Waiting to install the hertz speakers until the door chime module arrives. I’m starting to wonder if running all this off my stock head unit is detrimental to the sound quality. Am I just amplifying a bad signal?
LOCs? The sub sounds great at lower volumes but when I start to push it it seems to get a bit muddy and distorted. I guess I just expected the w3 to be tighter and cleaner sounding. It could be that I’m used to my 12” type-r in the back of my jeep and I’m pushing that little 10 too hard, but it seems like it’s happy just dirty if that makes sense haha. It could also be that I don’t have the speakers in yet and when I get some quality low end from the speakers things will tighten up. It could also be that the stealth box is right beside me inside my center console so the close proximity could make it so I’m hearing more undesirable things. I plan to upgrade the head unit someday just to get more eq/sub control and such but was going to wait a while for that. I play electric guitar and know that every little piece in the signal chain can have an affect on your sound so I just wanted to make sure I wasn’t leaving a bunch of sound quality on the table by running the factory head unit.
Line out converters. You can go very cheap or spend quite a bit to be able to tweak almost everything. No experience with the w3 but I’d say it’s likely getting a dirty signal. How is your sub amp getting signal?
I just had a shop handle the install as I don’t have a lot of knowledge of car audio so I’m not sure how it is hooked up. I just looked at the receipt for the install and I don’t see any kind of interface/module for the stereo. I do see a metra axdsplgl9 which I thought was just for door chimes but maybe that’s the overall interface as well. I’m still waiting for that to come in so they can install that and the speakers so maybe they did some kind of jerry rigged work around to get me by for now until then and that’s why it sounds off.
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, so basically it’s still a ground loop? But then why would the alt whine go away but the other constant whine stay Sorry I’m just pretty new...
8
Have you contacted crutchfield.com support. They sell modules that allow you to retain the steering wheel-controlled factory features for some...
9
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Madeinoregon
CarAudio.com Newbie
Madeinoregon
Portland, OR
Firewalker
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
