Is the amp ok to power the 2 subs?
  • 2
ianik777
CarAudio.com Regular
131
6
Mauritius
Pioneer amp 9601
  • Number of ChannelsMono
  • Maximum Power Output2,400 W
  • Continuous Power Output (1Ω, ≤ 1% THD+N)1,200 W x 1
  • Continuous Power Output (2Ω, ≤ 1% THD+N)800 W x 1
  • Continuous Power Output (4Ω, ≤ 1% THD+N)500 W x 1
  • Continuous Power Output Bridged (4Ω)―
  • Frequency Response10 Hz to 240 Hz
  • Total Harmonic Distortion (4Ω)< 0.5% (100 Hz)
  • Signal-to-Noise Ratio (IHF-A Weighted, at 1 kHz)> 100 dB
2 x pioneer sub
  • System TypeComponent Subwoofer
  • Sensitivity (1W/1m)96 dB
  • Frequency Range20 Hz to 80 Hz
  • Warranty1 Year
  • Continuous Power handling (RMS) - Watts600 Watts
  • Maximum Peak Power Handling - Watts2000 Watts
  • Nominal Impedance - OHM4 DVC
are the 2 subs underpowered?
Probably a safe bet that two "600W" continuous subs and "1200W" continuous amplifier from the same (reputable) company are designed to be a good match with each other. Might help if you post the exact model number of those subs you plan to buy.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
Hopefully it is ok to post a "for sale" ad on here. If not, I apologize in advance. Fully serviced Earthquake PHD2 amp for sale. Asking $175...
ianik777
ianik777
Mauritius
hispls
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
