is there a way to tell wattage from an amp using a DMM
while there are many factors, it may be best to just go off the voltage reading only. here is why:
why do you want to measure power? Normally to benchtest an amplifier. This generally is done to compare amplifiers, in which case standard conditions (test load, distortion limits, ect) are needed. Another use is to determine how much power your woofer is getting. But a simple voltage reading is sufficient to determine more power or less power.
So at this point you can upgrade, either to a clamp meter, or a crude OScope. the OScope can give you information on distortion, which can make the more/less power WITHOUT DISTORTION measurment more accurate, though it cannot garuntee that the amp will not clip if the battery voltage falls.
The clamp measures current. But, because the speaker can convert electrical energy to mechanical energy (and back), impedance can change with freqeuncy, and in sealed boxes this can be very significant (eg, by a factor of 10). because the woofer tends to be very efficient at such frequencies this reduction in power isn't noticable. So this means that you can end up reading something small, like 50W. (at 40 ohm) instead of 500W (at 4 Ohm). Also, you cannot measure distortion as effectively. But, you can measure impedance rise from this.
Also, you don't know if the peaks of the voltage align with the peaks of current. such a condition occurs when energy is put into moving the cone (or compressing air) only to be reclaimed at a later time. This makes it very common. still this "bouncing" of energy is "conservative". it isn't power as, over a long period of time no work is actually being done. but it does cause the DMM and Clamp to read high voltages and high currents. A 2 channel OScope with a current probe can allow you to see both voltage and current and how well they line up. More advanced versions will have a multiply function that can plot power (and find average power) over time. They may also have spectral analysis (FFT) allowing a measurement of distortion/noise.
but at the same time, is this much information actually useful? for learning, yes. for developing DIY equipment, yes. for researching speakers? yes. for benchmarking amps, not yet (still need a standard test load). for tuning boxes, yes
nice fox news quote.
thanks for the info....i was just playin with the setup just curious.
im getting around 90-95 vac when i have my settings normal........and volume at the highest that i play it at...
I Dont think so. You can use it to set the gain but as for finding actual rms your gonna need a voltage reading and amperage reading
how do you use the dmm to set the gain, and check ohm load. I went and bought one some years ago and lost the manual . doh:(
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
520
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
iamamp3pimp
