Is this a great deal? HELP!!!
  • 2
goofydawg1977
1 Digital Design 12" 3512 sub with professionally designed ported box both in great condition for $260
I already have a 12" FI BL but I thought this was a good deal so I jumped on it. I know they're known for their spl but are their sound quality ok? I need advice. I'm about to pick it up in couple hours. 4OHM
generally yes thats a good deal depending on the actual condition of the dd3512 the sub alone is worth that.
idk where that 4ohm at the end fits in the dd should be d.5, d1, d2,d4, q1, d.7, d1.4 though they do make custom coils they never mad a single voice coil 3500
and the bl is a better sub for daily ground pounding where as the dd is more spl geared and like to be tuned a bit higher
Ok,,,thanks a lot for such a quick response. It helped.
just get a ddm and check the coils first also you might want to actually look at the coil before you buy. take it out of the box and look it should be nice a shiny copper. if it isnt dont even bother.
Right on! Thanks for that info. Every bit of info is appreciated. Aloha
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
4
946
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
5
goofydawg1977
goofydawg1977
United States
goofydawg1977
winkychevelle
    Jun 3, 2024
