Is this fuse required to get power to the amp? (see pic)
  • 5
I've just installed a new stereo but I can't get my amp to turn on for some reason. I've quadruple checked every connection I know to check and I'm thinking it could be either:
1. The amp is broken.
2. The remote on cable might not be getting its 12 volts from the deck and I should try hooking it to the red wire.
3. The fuse box on the amp power cable mysteriously lost its fuses. Is this fuse/fuses necessary to power the amp? The fuse box I am talking about is located on the amp power cable about a foot away from the battery. Check out the picture.
Any help is appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
678
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
660
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
NewLogic87
East Texas
Bassin Buick
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
