It's Logical! A rare high current from the past.
  • 4
Rodek
41
Alabama
Here's my old school high current Class AB Logic L24HC amp. It's a 2 channel and 1/2 ohm stable. It's also fan cooled! I believe it to be rated at 45 x 2 into 4 ohms and somewhere in the neighborhood of 350 watts at 1 ohm mono. Enjoy the peeks!
Gut pics remind me of the the old US Amps A series. Simple clean circuitry with amazing sonic clarity. Paired with a set of JBL T545s was quite a treat.
Yes! The circuitry is pretty simple and it actually sounds incredible. I haven't hooked it up in a while so I decided to get it out and let it run for a while. Very clean sounding with plenty of headroom.
I did not grow up with the brand and was under the impression it was fairly basic stuff (note that I did not say bad). I have a Logic Soundlabs TX1802 I think the model is, never used it, got it free with other stuff, but the guts look like it could do at least somewhat close to it's rating. No idea the real power, but had a decent amount of transistors in it.
The one the OP posted reminds me of the boards the old MA Audio HC and HX series / Audiobahn High Current amps used. I have a 2001 or so MA Audio HX series 1500w that is reminiscent of that, more transistors of course, but I did actually run it at 1/2 ohm and it held up fine.
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
9
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
4
5K
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
557
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
516
Rodek
Rodek
Alabama
Louisiana_CRX
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
